Help Installing Injen CAI
Old Feb 22, 2007 | 09:49 AM
bigfoot1986's Avatar
Default Help Installing Injen CAI
I need help installing an Injen CAI for my 94 civic DX. For this install it says to Remove the PCV pipe, I found where it is, how do i open it? do i just take a Flathead screwdriver and pop it open? And after i remove the pipe what do i do with the rest of the black cylinder that the pipe came from?
Old Feb 22, 2007 | 09:58 AM
FlipHKD720's Avatar
Default RE: Help Installing Injen CAI
You need to take EVERYTHING off from the throttle body to the end of the intake. Take all piping, filters, resonators, EVERYTHING out so that the throttle body is exposed. Put the new intake onto the throttle body nad use a rubber coupler to secure it (use a clamp on the intake and the throttle body, two clamps on the coupler) to attach it. Then put the filter on the end of the new intake and use another clamp to secure that.
Old Feb 22, 2007 | 10:17 AM
But i still need to know about how to get to the PCV pipe? Do i just take a flathead? And do i leave the rest of the black cylinder alone after i take out the PCV pipe?
Old Feb 22, 2007 | 10:32 AM
wirphotos's Avatar
PCV valve you should just be able to pull it out. It just fits inside a rubber gromet. I believe it comes with a new gromet so you just need to pull the sensor out... BUT DON'T PULL BY THE WIRES!!!!
Old Feb 22, 2007 | 10:58 AM
FlipHKD720's Avatar
yeah pull the grommet out of the old intake box and it should plug right into the new intake tube, simple as that. And the other hose, there should be a nipple (haha) that it should slide into on the new intake tube
Old Feb 23, 2007 | 04:27 AM
danzel's Avatar
Before installing an Injen cold air intake for your 94 civic, be not afraid to ask assistance for the professional mechanics that will help you a lot and not to worry of what should be removed or not in your car.. or better have your car manual and help you guide installing injen for your cold air intake system.. gud luck!
KoshaK
Aug 10, 2007 10:37 AM
tknaub
13
Nov 20, 2006 09:08 AM
civic x
Aug 24, 2006 01:19 PM
importcivicus
Intake, Header, & Exhaust
Jul 12, 2006 09:19 PM
ABruinForLife
Dec 14, 2004 08:12 PM
