Help with O2 Sensor
Old Sep 19, 2008 | 06:12 PM
Dark246's Avatar
Default Help with O2 Sensor
Ok. My 99 Civic is straight piped from the manifold back without a Catalytic Converter.
And the car will not pass emissions without the O2 sensor plugged in to the Cat.
So I was wondering, My intake has a hole where the O2 sensor fits in perfectly. I plugged it in and the car still runs fine. I would just like to know if itll pass emissions if the sensor is plugged into the air intake.
Side View of the intake before O2 Sensor plugged in.
Top view now that its plugged in
Close Up
Closer
Much feedback is appreciated. Thanks
Old Sep 20, 2008 | 05:32 AM
TheShimster91HB's Avatar
The o2 sensor measures the amount of unburned oxygen in the EXHAUST. Having the sensor in the intake will cause the computer to read nothing but oxygen and will try to add more fuel to compensate. This leads to running very rich and will give horrible gas mileage and will most likely make you fail the test. Just because something fits somewhere doesnt mean that you should shove it in there...that can get you into lots of trouble.
Old Sep 20, 2008 | 06:12 AM
I think your 99 Civic has a D16Y7 engine. If so, the primary O2 sensor should be inserted into the exhaust manifold. Is the primary O2 sensor shown in your pictures? Where is your secondary O2 sensor?
Old Sep 20, 2008 | 06:51 AM
Dark246's Avatar
The other one is in the exhaust manifold
Old Sep 20, 2008 | 06:54 AM
Dark246's Avatar
And What if I hook up an O2 simulator to that seonsor. Because I would rather not put my old manifold and Cat converter back on
Old Sep 20, 2008 | 07:14 AM
Does your state require you to have a catalytic converter? If not, replacing your secondary O2 sensor with a simulator should eliminate the CEL.
Old Sep 21, 2008 | 08:22 AM
Dark246's Avatar
yes, my state requires the cat converter.
Old Sep 22, 2008 | 01:05 PM
brutekiller787's Avatar
then you are a bad person.
just get a magnaflow cat and an EX exhaust and it should go away if you put the secondary after the cat and primary before.
addiction2bass
Aug 14, 2008 09:53 PM
fglaustin
Mar 27, 2008 08:29 PM
vtec02
May 9, 2007 05:17 AM
00sithrottle
May 12, 2005 10:25 AM
