Installing intake manifold ques
Old May 31, 2006 | 03:26 PM
CiViCeXB's Avatar
Default Installing intake manifold ques
i just purchased a skunk2 prointake manifold for my b18c1-b16head can i just bolt it on or do i need to do other procedures to get it runnnning?
Old May 31, 2006 | 03:30 PM
Street Sniper's Avatar
Default RE: Installing intake manifold ques
Should just bolt right up. Make sure you use a new gasket and clean the old one off really well.
Old May 31, 2006 | 05:35 PM
uk civhead's Avatar
Mine needed modification, had to drill out one of the sensor hole's as it was threaded and shouldnt of been, I also had to extend a sensor wire, use a longer hose for one of the vacuum line's, and bend the throttle adjustment mount thingy to make it fit. Have fun now!
Old May 31, 2006 | 07:34 PM
CiViCeXB's Avatar
damn i couldnt get to the bolts on the bottom of the intake mani and **** i forgot about the coolant any now i gotta clean ****, thanks for the advice guys, i ll try again tommorow
Old May 31, 2006 | 11:14 PM
riceburner700's Avatar
you forgot about the coolent? wow i bet that was quiet a little mess... easier if you get the bottom bolts from the underside like if you are under the car unless you have all kinds of wiggling extensions then its a piece of cake
Old Jun 1, 2006 | 05:35 AM
BoostEK's Avatar
ORIGINAL: Street Sniper
Heed this warning carefully. I just did a Skunk2 install on my car and I forgot to scrape **ALL** the old gasket material off. The car immediately revved to 5k when started and burned coolant because it was leaking into my #1 cylinder. I used a chisel and a sanding block from ACE hardware. Just make sure to cover your ports properly because of the dust/particle matter!
JDMRDCiViC95
Jan 5, 2007 12:15 AM
CiViCeXB
Sep 2, 2006 02:46 PM
jobu03
Nov 10, 2005 11:18 AM
Shinumura
EG Swaps
Aug 21, 2005 02:54 AM
SoCaL.rider
Jun 12, 2005 09:16 PM
