Installing SRI....HELP!!!
Old Dec 22, 2006 | 03:11 AM
B!@ckBoYwiTaC!v!c's Avatar
Default Installing SRI....HELP!!!
Okay i just got my short ram intake in the mail yesterday and i am going to install it myself on my 2002 automatic civic ex coupe,but i'm having difficulty following the K & N instructions for a cai (figure i'll follow that and it'll be easier with sri) because i don't know what these certain parts are for and how to use them with the SRI. So i'm going to post pictures of the instructions i'm follwing, my sri, and also the hardware parts i'm having difficulty understanding what to do with them
Instructions: http://www.geocities.com/darkcami/CAIinstallation.pdf
SRI and Parts (that i don't know how to use them)
So can someone please tell me how in the hell do i use those two metal pieces for my SRI?
[IMG]local://upfiles/15787/99E4F68B93174B56A167ECC63987CBA6.jpg[/IMG]
[IMG]local://upfiles/15787/FC2205CE56EA4C1582B517526BBEE059.jpg[/IMG]
Old Dec 22, 2006 | 09:03 AM
drbyers's Avatar
Default RE: Installing SRI....HELP!!!
those look like bendable metal hangers, but I'm not totally sure.
if they are, they're used to connect hoses to the engine bay by bending then around the hoses and drilling a screw or bolt through one of the holes and into the wall or surface of your enginebay somewhere.
i would suggest you not drilling into your engine bay unless abolutely necessary.
Old Dec 22, 2006 | 09:51 AM
Fiirkan's Avatar
Mine came with similar metal pieces, they are used to bolt the SRI secure, i used one of the stock airbox bolt locations to secure mine, otherwise it is floppin arround in the engine bay when driving and it would eventually come loose
Old Dec 22, 2006 | 09:56 AM
ORIGINAL: Fiirkan
I figured that, but how do you use it. How do you secure it. I don't see a spot where it goes on the SRI.
Old Dec 22, 2006 | 10:00 AM
mxs's Avatar
mxs
ORIGINAL: B!@ckBoYwiTaC!v!c
no way, you're using directions for the wrong product for the wrong company, of course it won't work.
did you take out your stock airbox yet? you should find a place to attach the intake somewhere under there
Old Dec 22, 2006 | 10:06 AM
Fiirkan's Avatar
ORIGINAL: Fiirkan
You put one end of it in behind the clamp holding the filter one, and either bolt the other one to it and bolt that down, owr what i did, was bend the longer piece so that it will bolt to a factory bolt hole, and then put the other end behind the clamp holding the filter on... sounds more complicated then it is...
Old Dec 22, 2006 | 11:00 AM
o mxs i was just using those instructions as guidelines to make sure to connect certain things like the sensors in the correct place. And Fiirkan i think i might have it, so thanks, now i'ma try to install it, if i run into any problems i wont hesitate to voice them. lol
Damname
Mar 14, 2011 08:19 PM
snaowke
Oct 20, 2008 03:47 AM
Stumasters
Feb 25, 2007 10:03 PM
jonyg98civicex
Feb 15, 2006 01:09 AM
Auto98EX
Sep 21, 2005 10:37 AM
