intake installation
Old Oct 23, 2007 | 10:26 AM
fleetwood's Avatar
Default intake installation
Help....I was told I could find directions on installing a short ram intake on this website....any suggestions on where to find that info....bought it from another civic driver on this website and he told me there would be instructions on this site.....HELP
thanks
Fleet
Old Oct 23, 2007 | 10:32 AM
95civic1.6l's Avatar
Default RE: intake installation
what year is your car? what model?
Old Oct 23, 2007 | 10:40 AM
It's simple to install.
1. Remove your stock air filter tubes
2. Take off the cover from the air filter system itself (it should be in two parts)
3. Pull hard enough and "pop" off the filter box itself from the intake valve
4. Once you have everything from the stock air filter removed, you are free to install your cold air
5. Mine used 2 rubber connections to seal the aluminum cold air pipe to the car and to seal them to one another
6. Take your first (more curved piece) and connect it to the rubber and then to the intake port. Seal it with the clamps they should have given you.
7. Now you can screw in the other peice to the car and then seal it to the end of the first piece of aluminum piping.
8. Now you are ready for your filter at the bottom. Get under the car and pop off the little black clips holding the under bumper plastic together on the left side (if looking at the car from headlights)
9. Pull the plastic down, reach up and seal your filter to the piping that is already waiting for you.
10. And you're done
Old Oct 23, 2007 | 02:20 PM
my05civic's Avatar
^ you forgot to say "disconnect the negative battery terminal"
also, for all cars, it should be similar
Old Oct 23, 2007 | 02:34 PM
lol he said short ram, not cold air
so basically, follow 95civic's instructions up until about step 4. It honestly basically is "remove the stock intake, put your new one on.". A SRI was the first thing I did to my civic (way back when I had zero mechanical knowledge)... it's definitely an easy install for beginners (and it helps you get a little more familiar with the engine bay). Goot luck on it
Old Oct 23, 2007 | 02:39 PM
take pictures.
Old Oct 24, 2007 | 07:26 AM
warner_ro's Avatar
i should have gotten a SRI, i had to drain some of the coolant, cut some of the wheel well, and also remove the entire battery.
07' SI, they said it was an easy install, which is was, but took almost 2 hours. pain in the .....
Old Oct 24, 2007 | 07:31 AM
KoshaK's Avatar
ORIGINAL: warner_ro
Yep....haha
Old Oct 26, 2007 | 06:44 AM
fleetwood's Avatar
Thanks to all for your help....plan on contributing to Honda Heaven when I can!!!!!!
Fleet
Old Oct 26, 2007 | 06:46 AM
you can contribute by posting pictures if you want. lol of your intake on your car
strtballer98
May 20, 2007 08:39 PM
Patrick
Drivetrain DIYs
Jul 12, 2006 02:07 PM
Ei8
Apr 19, 2006 06:55 PM
JaxsWastedLife
Apr 19, 2006 01:29 PM
CivicRcR07
Feb 26, 2006 10:10 AM
