need help finding o2 sensors
Old Sep 15, 2008 | 05:51 PM
brutekiller787's Avatar
well i don't see how because nothing besides the connector is exposed from the plastic covering. but i will check and let you know. how much do you think a brand new wiring harness installed by honda costs?
Old Sep 15, 2008 | 05:57 PM
The wire could be damaged anywhere between the sensor and the ECU. If the wires are fine, then you may need to consider that the ECU itself is bad.
Old Sep 15, 2008 | 06:00 PM
so i should just check the connections on the ecu and then check voltage on the heater side of the o2 connector?
Old Sep 15, 2008 | 06:06 PM
At the disconnected ECU connector, make the voltage and resistance measurements shown on the second page of the diagrams.
cowsgonemadd3
Dec 8, 2008 08:03 PM
lethan7
Oct 8, 2006 10:18 AM
LEVIII
May 26, 2006 06:20 AM
Falcon6
May 7, 2006 09:48 PM
funnyact
Apr 12, 2006 02:41 PM
