need help on my catalityc converter # 2
Old May 31, 2007 | 02:58 PM
02si's Avatar
Default need help on my catalityc converter # 2
hi, i posted a thread a couple of days ago. i took my car to a place cause i needed to replace my catalityc converter but they said that i am not going to be able to replace it unless i get it from the dealer and thats like $1000.00 right there any suggestions on where to replace it or if its true that i cant get it somerwhere else besides the dealer? please help me out guys cause thats a lot of money right there for a catalityc, the catalytic has two sensors i think thats why is that expensive, i need help with this.
edgar
socal
Old May 31, 2007 | 03:59 PM
rice99ex's Avatar
From: Utica, NY (home of The Saranac Brewing Co.) :)
Default RE: need help on my catalityc converter # 2
are you sure that theer are 2 sensors on the cat? Either way you could keep your old sensors, and you do not have to go to the dealership you could search around for a high flow cat online. Im assuming your car is a 2002, what is wrong with the cat, i still have my stock cat on a 99, works fine.
Old May 31, 2007 | 04:20 PM
02si's Avatar
yeah theres is two sensors they both look like spark plugs, i dont really know whats wrong with the cat one day my engine light came on so i had a diagnosis done to it they said it was the sensors that were broke that i needed to replace them but then they said it was the catalityc that was broken. the car lost power since the engine light came on and the cat. converter is broken.
Old May 31, 2007 | 04:32 PM
Mr Mobsta Man's Avatar
It's probably clogged. Just look around for a high flow cat if you want to upgrade while your at it or you could go around to junk yards and get one off another car and replace yours with it. Do the work yourself it's not difficult and it will save you some money. The things you are talking about that look like spark plugs are called o2 sensors.
Old May 31, 2007 | 04:40 PM
02si's Avatar
what do you mean when you say "hi flow cat", does it mean that i can get one like that and is gonna cost me less money, what about the o2 sensors, i dont know what to do!!!! where can i find those "hi flow cats", please tell me exactly what to do!!
thanks
edgar
socal
Old May 31, 2007 | 04:45 PM
Default RE: need help on my catalytic converter # 2
high not hi. It's a performance catalytic converter, it gives you a few more horse power than the stock catalytic converter does. It would probably cost more than a stock catalytic converter would run you. What do you need to know about the o2 sensors? Are you sure what is actually wrong. Are the o2 sensors broken and need replaced or is it the catalytic converter that isn't working properly?
Old May 31, 2007 | 05:34 PM
FlipHKD720's Avatar
you can find a universal cat online for a good price, dont get an "ebay high-flow cat", because they are actaully test pipes and do nothing for emissions. Replace the cat, and if you still get a CEL, then replace the sensors. Or the other way around.
Old May 31, 2007 | 05:48 PM
02si's Avatar
its just that first i took yo a regular place to get the diagnosis and they told me it was the o2 sensors and when i took it to the dealer they said it was the catalityc
Old May 31, 2007 | 06:46 PM
lol It's probably the o2 sensors then, the stealership is probably just trying to get as much money out of you as possible. I can't be sure though. Go to an Autozone and have them check the code the cel is throwing and they will tell you how to fix it.
Flip, I wouldn't go with a universal cat if I were him. I think they have fitment issues and just make it a pain in the *** to install. If your going to get an aftermarket one then get one made specifically for your make, model, and year (generation).
Old May 31, 2007 | 06:56 PM
02si's Avatar
thank you ill do that any other suggestions are welcome.
edgar
socal
