need help!! read asap! what is this!pic's!
Old May 16, 2008 | 03:05 PM
enigma34's Avatar
Default need help!! read asap! what is this!pic's!
IM INSTALING A NEW exhaust and, i dont know if i need to use this? it was between the mid pip and stock exhaust system.
what is it?
http://i30.tinypic.com/33wqkar.jpg
http://i26.tinypic.com/jrvfd0.jpg
Old May 16, 2008 | 04:03 PM
enigma34's Avatar
Default RE: need help!! read asap! what is this!pic's!
i putt the aftermarket exhaust on, but there is some air coming out where the exhaust meets the mid pip... so i may have it on wrong, but ill take it out and put the exhaust on without it, and see if there is still air coming out..
Old May 16, 2008 | 04:12 PM
colby_666's Avatar
its a type of seal that goes between the two pipes you mentioned, most after market exhausts come with a replacement one or you can get a new one, you need some type of seal there or it will leak
Old May 16, 2008 | 04:41 PM
enigma34's Avatar
ORIGINAL: colby_666
i have the seal in there now, and it is leaking air!! so what can i do? the bolt have a spring on one end, i have it on there as tight as it will go on. so maby it can go tighter, but i dont wnat to break anthing? idk, but the seal is between there and im still leaking.....any help on whast going on??
Old May 16, 2008 | 05:16 PM
enigma34's Avatar
dammmm...cry,cry... i broke one of the bolts....i prbly have some bolts laying around, but damm...
so, i dont know what to do.. the seal is fine, but it still leaks...
Old May 16, 2008 | 06:05 PM
enigma34's Avatar
so, i dont have an air leak any more, now that im using a bolt with out the spring.. so, do i need the springs? i think i will be fine if i just go and by some bolts and just use them and not tthe one with the spring? i think it was giving me the air leak because the blots witht the springs were not long enuff?
Old May 16, 2008 | 06:32 PM
danomatic93's Avatar
June 2010 ROTM
You need to replace that "donut" gasket with a NEW one. The spings allow the exhaust flex when the engine rocks. Otherwise you are pulling on your exhaust all the time.
Old May 16, 2008 | 06:49 PM
enigma34's Avatar
ORIGINAL: danomatic93
Is it ok to pull on the exhaust? there isnt an air leak, so i dont need a new donut gasket?
I was geting the leak becasue the stock bolts were not long enuff to fill the gap, between the muffler and mid pip?
So my problem was that i need longer bolt's.To find this out on my own, i had to over tightn and breakone of the stock bolts lol....
Old May 16, 2008 | 07:12 PM
June 2010 ROTM
lol, I suggest getting a new gasket and get bolts/washers/nuts that are long enough to still use the springs and tighten them down.
Old May 16, 2008 | 07:16 PM
conceptualpolymer's Avatar
That seal looks like it's been shot - I'd get a new one or use the one that came with the cat-back. The springs serve a purpose - they allow for differential expansion and contraction of the pipes and flanges. Did the new exhaust come with instructions? See my sig for a link to my DIYs. You'll see how I installed my Magnaflows.
