porting?
Old Mar 2, 2007 | 09:05 PM
jc6711's Avatar
Default porting?
is it possible to port the intake maniflod by your self, and head, like with a dremel.
Old Mar 2, 2007 | 09:16 PM
ef4life's Avatar
Default RE: porting?
yes but its not recommended unless you know what you are doing.
Old Mar 2, 2007 | 09:43 PM
my05civic's Avatar
it takes a lot of skill to make it even with a dremel
Old Mar 2, 2007 | 11:07 PM
riceburner700's Avatar
i wouldnt recommend a dremel at all
Old Mar 3, 2007 | 12:17 AM
my05civic's Avatar
me neither. but it can be done.
Old Mar 3, 2007 | 11:06 AM
project5k's Avatar
let me see if i understand the point to this, theoritically the inside of the ports on the head and the manifold are rough from when they were cast.. so your looking to smooth that out and reduce the turbulance... in addition to that your looking to make the actual port holes line up exactly with the gasket and other holes, so that the air moves smoothly, rather than the ports in the head being bigger than the holes in the gasket, so the air swirlys around shen it goes through?
sounds like several hours with the diegrinder to me... but should be as cheap as a set of gaskets...
pregohatch
Mar 28, 2006 06:37 PM
pregohatch
Mar 28, 2006 07:17 AM
86shelby15psi
Mar 1, 2006 09:41 PM
brokenarmboy19
Aug 25, 2005 08:27 AM
Pete
Apr 21, 2005 09:22 PM
