Preferred Catback System?
I have a 2001 Civic DX, and if you dont know, the DX catback systems are different than the EX systems which makes it harder to find one.
If you could leave your opinion on what would be the route for me to go with an exhaust system, that will not make my car sound like a lawnmower.
ORIGINAL: mybrokenblinker
umm...103 vs. 127. Yes it is noticeably faster.
D17A1 [ul][*]Found in: [ul][*]2001-2005 Honda Civic DX/LX/VP [ul][*]Displacement: 1668 cm3[*]Bore and Stroke: 75 mm X 94.4 mm[*]Compression: 9.5:1[*]Power: 115 hp @ 6100 rpm & 110 ft·lbf @ 4500 rpm[*]Valvetrain: SOHC[*]Fuel Control: OBD-2 MPFI[/ul] [/ul] [/ul]D17A2 [ul][*]VTEC-E[*]Found in: [ul][*]2001-2005 Honda Civic EX[*]2001-2005 Honda Civic Si (Canada only) [ul][*]Displacement: 1668 cm3[*]Bore and Stroke: 74.98 mm X 94.4 mm[*]Compression: 9.9:1[*]Power: 127 hp @ 6300 rpm & 114 ft·lbf @ 4400 rpm[*]Valvetrain: SOHC VTEC-E[*]Fuel Control: OBD-2 MPFI[/ul] [/ul] [/ul]
i would say go custom, shouldnt be 500, i would think less. especially if you yourself know how to weld. my buddy made his with 2.5" pipeing and a N1 muffler. (i think it's N1), anyway, sounds pretty good, not totally a lawnmower. decent i'd say. for your car, i'd say 2.25" inch pipeing. shouldnt be more then a could hundred bucks...3-400
NIKE H34D
Jul 6, 2010 05:31 AM
sks
May 29, 2006 06:06 PM
