Throttle Body swap question, will it fit?
Old Oct 17, 2006 | 11:08 AM
Fiasco's Avatar
Default Throttle Body swap question, will it fit?
Heres the link. I got a bad skunk 2 and will never use them again. Does this look good enough.
http://cgi.ebay.com/ebaymotors/Integ...41572320QQrdZ1
and will it fit. I am under the impression the B and D TB's are interchangable...correct or no?
Old Oct 17, 2006 | 12:05 PM
Remmy's Avatar
Default RE: Throttle Body swap question, will it fit?
Pete had an issue with the Skunk 2 I/M
Old Oct 17, 2006 | 12:14 PM
uk civhead's Avatar
Yes it will fit a D, just make sure its port matched to the mani your using.
Old Oct 17, 2006 | 01:00 PM
Fiasco's Avatar
How hard is that to pull off? (port matching?
Old Oct 17, 2006 | 01:02 PM
phishy's Avatar
Sorry guys I'm a noob but what is the point of swaping out TBs? What are the pros of it? Also what is the mm size of a TB on a D series motor, will say D16y8 my motor.
Old Oct 17, 2006 | 01:09 PM
D16Punk's Avatar
ORIGINAL: phishy
Swapping the stock tb for a bigger one alows more air through.
As for the guy who started the post, I dunno if I'd go 65 mm, most people recommend 60, 62mm tops for them. I also don't know how much the stock intake manifold can be ported to, so you may want to find that out first. Just my .02.
Old Oct 17, 2006 | 02:39 PM
Fiasco's Avatar
thanks man. I have the Skunk 2 IM, so im thinking 62-65mm would be good. I had a S2 68mm and it sucked.
xjreazyx
EG Swaps
Feb 3, 2007 10:37 AM
StifflersMom
Oct 9, 2006 10:52 PM
psychocivic
Feb 8, 2006 06:37 AM
pbrooks259
Oct 3, 2005 11:06 AM
