95 Climate Control
Old Sep 25, 2005 | 10:38 PM
WillVTEC's Avatar
Default 95 Climate Control
Hi, I own a 95 Civic EX and been trying to get the climate control out of the dash so I can replace the bulbs which are out, been trying several times and havent figure out how the get the darn thing out, I removed the ashtray/lighter console, the radio and have removed the 4 screwas that Haynes manual indicates without luck, and I just dont want to yank it out because dont wanna break anything since the winter is coming and winters in RI are brutal, has any of you any idea or trick to get it out the right way, thanks....
Old Oct 4, 2005 | 11:02 PM
WillVTEC's Avatar
Default RE: 95 Climate Control
Aparently no one wants to help, I wonder what this site is for then
Old Oct 4, 2005 | 11:24 PM
Dogmeat's Avatar
sometimes good things come to those that wait. (longer than a half hour)[sm=bananallama.gif]
Old Oct 4, 2005 | 11:27 PM
Dogmeat's Avatar
read this
http://honda-tech.com/zerothread?id=661308
that should answer any questions...if not count to 10 and try again
Old Oct 5, 2005 | 11:18 AM
Super Mario's Avatar
you have to remove just about the entire dash to get to it. the dash/trim piece that goes around the steering wheel and has the dimmer switch on it on the left side, has to come out. The screws are inside the dash, so you have to get to it from behind. in my opinion it/s really not worth it to go through all that trouble just to replace a couple of bulbs. Try going to a dealer and asking what it would cost to replace, or how to replace those bulbs. I thought I had the same problem, but I just pounded on the dash a few times and it was probably a bad or loose connection. I noticed it would flicker form time to time. Unless you are good with interior pieces, and figuring out the trick to them, it's really not worth it, you've got to take apart the entire dash. Good luck Though!
Old Oct 5, 2005 | 07:46 PM
WillVTEC's Avatar
Thank you for the info, I appreciate it
new_2_civics
Apr 1, 2010 02:37 AM
Forty04
Dec 27, 2006 12:43 PM
ninjapimp
15
Nov 13, 2006 08:21 AM
ashcheerit2000
Nov 11, 2006 12:17 PM
jaymacf3
May 24, 2006 03:32 PM
