Crap inside my projector
Old May 27, 2006 | 10:02 PM
tdci29's Avatar
Default Crap inside my projector
does anyone know how to clean the inside of a headlight, someone spit in it or something, im just hoping i dont have to put it in the oven to open it... i got a picture of it too!
[IMG][/IMG]
Old May 28, 2006 | 12:36 AM
riceburner700's Avatar
Default RE: Crap inside my projector
there is no screws or tabs holding it together?
Old May 28, 2006 | 01:18 AM
tdci29's Avatar
there are tabs that hold the lense and housing together, but they're held together by cilicone....
Old May 28, 2006 | 03:23 AM
thedougler's Avatar
that sucks...thats kinda sick how would they spit inside it?
Old May 28, 2006 | 11:20 AM
ScoobyAddict14's Avatar
formerly aryiman98civic
your going to have to take the light apart to get that out, pretty sick though
Old May 28, 2006 | 06:27 PM
just get it open carfefully and when you are done just get some more silicone and reapply it back to the light to seal it up because oviesly the silicone wasnt applied everywere and should of never fogged up like that, if it was properly sealed
Old May 28, 2006 | 07:25 PM
mill$civic's Avatar
i got the same headlights as you..what you could try before you take it apart is get something like like a really skinny ruler or anything you can find that fits into the turn signal hole, put a moist cloth over what ever your going to use and put it in the hole and try to give it a wipe..should work
Old May 28, 2006 | 07:41 PM
tdci29's Avatar
i tryed that already and it started to work, but the thing i was using was too short and not flexible enough....
Old May 28, 2006 | 07:43 PM
tdci29's Avatar
i thought about that too, but in order to get the cilicone off wouldn't you have to melt it in the oven first, or can i just take it off?
Old May 28, 2006 | 08:46 PM
mill$civic's Avatar
get something longer and more felxibleits better then taking off the silicone, ya you would need to heat it up, you can use a heat gun or try a blow dryer as well..i would be afrade to put them in the oven...also a sharp razer blade and cut through the silicone, then it should be easy to pull apart..get some weather proof,felxible silicone to seal it back up
StifflersMom
Nov 8, 2006 10:30 AM
Forty04
Jul 11, 2005 08:24 AM
kazunori
Jun 27, 2005 09:37 PM
Cappelle
May 2, 2005 04:02 PM
PicknFLick
Jan 23, 2005 10:09 PM
