debadging help
Old Apr 23, 2009 | 07:33 PM
lement92's Avatar
Default debadging help
alright. i just kinda finished debadging my car today. followed the DIY on here exactly. but there's still some adhesive residue left. i had tried alcohol and goo gone. used a plastic scraper. even hand washed it with a rag. there is still some residue left. if you look at it, you can still tell clearly what it said. is there something, maybe better than goo gone, to get this last little bit off?
Old Apr 23, 2009 | 07:59 PM
Superfly's Avatar
Ya i had that problem....ummm not sure if it will do the trick but try a clay bar
This could be a horrible idea, but maybe mineral spirits or lacquer thinner? Pretty sure that will take off the clear coat though......
Old Apr 23, 2009 | 08:07 PM
lement92's Avatar
what's a clay bar? i tried a white eraser like the DIY says and that didn't work worth a ****.
Old Apr 23, 2009 | 08:19 PM
Superfly's Avatar
Go to autozone or something and ask for a Mother's Clay bar. It helps take off weather elements and such
Old Apr 23, 2009 | 08:27 PM
lement92's Avatar
cool. thanks.
Old Apr 23, 2009 | 09:30 PM
trying using some rubbing compound. your going to need to keep working on it. going to need some elbow grease for this one
Old Apr 23, 2009 | 10:26 PM
be very careful doing that
don't buff it for too long
Old Apr 23, 2009 | 10:29 PM
lement92's Avatar
ok. i'm rather new to the game. what is rubbing compound?
Old Apr 23, 2009 | 10:32 PM
it's basically polishing compound that cuts harder
it's for removing bigger imperfections than polishing compound can. you use it first to remove the imperfection, then you polish with polishing compound to bring the clear shine back.
don't buff the rubbing compound for too long, you'll eat through the clear coat.
Old Apr 23, 2009 | 10:34 PM
lement92's Avatar
think i'll make that a last resort. gonna pick up the clay bar and give that a shot first.
