Dome and Map Light Replacement w/ LED's
I have an 07 Civic EX and I want to replace the bulbs in the map lights/dome light with LED's.
I know the bulb is DE3175 but I need to know who many millimeters the LED should be??
(ie: 31mm, 36mm, 39mm, 42mm, or 44mm)
Any help or guidance would be appreciated!
Autolumination has a bigger selection, but also it shows you what your bulb looks like, in your case the 3157 is 1-1/4" LONG (31MM) X 1" (24MM) WIDE Replaces: 3022 3021 3175 6428 6430.
Now you can use one of those units from autolumination, or you could check around on ebay, I found this unit:
I've got a similar set up in my dome lights in my civic (modified two pair of three 1wat led 7440 led replacment units into a dome light equalling 6 1wat led chips as this unit is), and I've got alot more light than with other set ups...
addiction2bass
Feb 25, 2008 01:24 PM
2007, bulb, changing, civic, dome, domes, honda, installation, led, light, lights, map, maplight, milimiters, mm, replacement, replacment
