Door Swap
Old Feb 2, 2009 | 06:51 AM
Buddhabusmc's Avatar
Default Door Swap
What is all involved with a door swap? I have a 93 EG hatch and I found some doors with power windows and locks and was just curious on what it would take to get them wired up and working properly. Thanks in advance.
Old Feb 2, 2009 | 08:00 AM
texasmade's Avatar
i belive all u would need to do is wire it to the fuse box
Old Feb 3, 2009 | 08:08 AM
you believe wrong
OP: your car's floor harness doesn't have the wires in it. You will either have to swap in the correct floor harness, or look up the wiring diagram and run all your own wires.
Old Feb 3, 2009 | 08:16 AM
texasmade's Avatar
you believe wrong
ok jerk off
Old Feb 3, 2009 | 02:54 PM
SPLAT's Avatar
Trustdestruction is right, sorry Texasmade.
Old Feb 3, 2009 | 03:24 PM
owned J/K
you could wire it up yourself BUT.... you need the harness plugs from the cabin... otherwise you have to cut the plug off and wire everything from the door to the inside cabin which wont look good at all. youd want to keep the stock wire loom and harness off the POWER vehicle..... its not going to be very easy.... the power locks are very easy but the windows might be alittle harder... but doable.... its not really difficult if you have the rest of the other car or a friend with the same car that has power options.
Old Feb 3, 2009 | 05:39 PM
That sounds like it might be a little more than I want to tackle. I wasn't sure on what it all would take so I figured I would ask the knowledgeable people here. Thanks for all of your input guys.
poop42
Dec 13, 2007 06:19 PM
Koala
Oct 12, 2007 09:38 PM
rcr510
Jul 3, 2007 02:03 PM
datasunny
Mar 24, 2007 11:09 PM
mrsuburban
Feb 11, 2007 07:43 PM
