Fiberglass Kit Hardening
Old Apr 19, 2005 | 10:30 AM
canadianhamster's Avatar
Default Fiberglass Kit Hardening
I dont know much about body kits except for the fact that I have one sitting in my garage waiting to be put on my car. It was a pretty cheap kit and I regret getting it now that I read all the stuff on this forum, but its to late now. I found a shop in town that is going to base coat, clear coat it for about $350 (whole kit). My friends and I installed it and it is aligned perfect. i was just wondering if there is any way to stiffen up the kit now or make it more durable in any way. Is there a hardening agent or even something i could add to the backside to stiffen it up more. My nieghbor offered to make metal braces for the corners but I would like to stiffen up the whole thing. please help!!!!
Old Apr 19, 2005 | 11:36 AM
ngoti 8tor's Avatar
Default RE: Fiberglass Kit Hardening
You can buy the fiberglass mesh and resin then add it to the back to make it thicker and stronger. Adding the metal peices or even wood will be even better as long as you cover them completely so that it won't rust or rot.
Old Apr 19, 2005 | 10:45 PM
altezza's Avatar
that or there are some companies if you have one in your area that can actually spray fiber glass on the inside to harden it up a buddy of mine had it done but i'd say go with the fiberglass mesh and do it that way
Old Apr 20, 2005 | 09:57 AM
I went to autozone to get some fiberglass mesh and its like $20.00 for a little bit of the stuff. Is there any other way to buy it in bigger sheets or in bulk? thanks again
Old Apr 20, 2005 | 10:21 AM
ngoti 8tor's Avatar
You'll have to check around in your area, but it is usually quite expensive. It may also be called fiberglass cloth. You could try going to a marine supply store and ask (they might be least expensive cause they use a lot). They use it to repair boat hulls.
Old Apr 20, 2005 | 10:34 AM
jwsimons's Avatar
i have sub contracted companys to do balconys for me. they do it with a fiberglass mesh, like a grid pattern 1/4" x 14" square's this is easier to use because of the air bubble problem,, try a building materials yard in your area, thgey may have several different options. or just type the word fiberglass in google, alot of dist's there
Old Apr 20, 2005 | 04:56 PM
bleedhondos's Avatar
you can get fiberglass cloth or mesh at a home depot store, Its really cheap.
Old Apr 21, 2005 | 10:33 AM
Thanks, I'll try all of those for the best price. Thanks again.
Old Apr 21, 2005 | 10:08 PM
ngoti 8tor's Avatar
Let us know how you make out, just in case someone else needs the same thing.
Old Apr 22, 2005 | 10:30 AM
I lined the lower lip of it with a small cut of wood as was recommended and then fiberglassed that to the bottom lip of the kit. From there I fabricate the metal braces with the assistance of my neighbor. I then skrewed the brace to the car and screwed the other end to the wooden reinforcement that we installed. From that it stiffened up very significantly but to further the durability I added some more fiberglass to the tabs that held it to the car and added some more to other questionable reason. So the lesson I learned was don't buy cheap kits, if you do you will spend roughly $100 to re-ensure its durability or else loss it down the road. thanks for the help
