first major interior dilema
im starting to customise my dash.
i wanted to move my heater switches to somewhere hidden in a new casing i made but i cant see how the hell i can move the heater panel.
has anyone done this or know anything to do this?
first of all check out what type controls it is.... its its all electrical that would be realy easy to move!!!!
but if it is cable driven its still posible BUT will be alittle tuffer... cause youll most likely have to buy some new cables that are longer to move them where ya need to...
BUT still very doable!!!!!!!
just as long as the cables are secured properly and working cables are secured properly also!
cause if the main cable moves the inner cable will bind and the inner cable cannt slip either...
BUT just check have to pull those types cables find out the length of them and buy some longer cables like at napa autoparts has some decent cables... just use some throttle cables from tractors
but if you have to trim the cables down i would advise puting a few drops of some good oil on each end and work it for alittle so it slides smoothly!
and bend the cables around the arms so its real tight! and depending on the stock cables ends will be how youll have to match it...
but if you have to trim the cables down i would advise puting a few drops of some good oil on each end and work it for alittle so it slides smoothly!and bend the cables around the arms so its real tight! and depending on the stock cables ends will be how youll have to match it...
