headlights
Hey, I did a little research for you since im looking for a part of the EL anyways..
So now the big questions: What fits? What do I do to convert? It is relatively easy to convert front ends. If you have an EK or EJ civic, the 96-00 1.6EL front clip is all you need – fenders, hood, headlights, bumper (with foam reinforcement dealie), bumper lights. You will have to extend your signal wiring so it runs down into the bumper instead of up at the headlight. Since the Civic and EL share the same doors and frame, the front end bolts right on with hardly a mod to speak of. The EM and ES Civics can just as easily bolt on a 1.7EL front end, using the same parts listed above. EL’s and Civics of equivalent years share the same doors and rear fenders. Swapping trunks to get the taillights is dead easy on both cars, but you WILL have to do something about the fact that EL’s of all years do not have keyholes in the trunk lid. They are remote-release only, either by cable next to the driver seat or the trunk button on the remote. You could probably just swap your keyless unit or deal with pulling the trunk release by your seat. If you want EL tails, you will have to swap your trunk and pick up the full taillight assembly. This will only work for Civic sedans. The 1.7’s rear disc brakes are easily swapped in, as evidenced by several cases on the forum, but from what I see, they’re just Si (Canadian=SiR) rotor/caliper assemblies anyway, no point going all the way to Canada for it.
The main problem with getting parts for an Acura EL to fit on a Civic is AVAILABILITY. No EL’s in the States means you have to go to Canada for everything. If you go to the dealership, I’ll tell you right now, an unpainted 04 EL bumper is $500 Canadian. Add paint, fenders, headlights (another $600 Canadian) bumper lights, and wiring, and you’re looking at a very expensive modification. May as well get that turbo right? Well, if you’re feelin lucky, you can try poking about in junkers in Canada – I see wrecked EL’s weekly. Problem is, if an EL is totaled and in a junker, it’s probably due to a smashed front or rear – the parts you’re looking for are history. But well, there you go, a brief rundown of the Acura EL and its relationship to the Honda Civic. I know I’ve missed something, please let me know if there are details you want me to add.[/align][/align]The full artical is here[/align]http://www.acuraworld.com/forums/showthread.php?t=53123[/align]
ORIGINAL: mill$civic
Oh and the part I was looking for was a folding mirror off a EL. I just called my local scrap yard. And JUST FOR 1 mirror. $150.
Cosworth
Dec 15, 2008 05:35 AM
AdamC
Jun 2, 2004 04:08 PM
