Installing headlights, need help FAST!
Old Dec 11, 2006 | 11:05 PM
armyg316's Avatar
Default Installing headlights, need help FAST!
Hey guys, new to the boards and to the Honda world I have a 2003 Civic Coupe EX and I got some Halo Projector Headlights off ebay
Check them out here
I started the install and have a few questions. First, are these good lights at all??
Next, I have a little issue. The one light that should go where the yellow side marker (running lights) does not fit. It doesn't even have the same pattern as the hole the housing has. Wondering if there is something I could do???
Also I don't know what to do with the yellow lights they included with the kit. They come on a harness (they are pictured in link) but the white clip that connects to the original wire does not fit. I believe this is the blinker. Stock blinker has three wires red, green and black and this one has 2. Blue and black. Wondering if I could splice the oem 3 wire to the included 2 wire. And if so which is which? I assume on the OEM one there is a ground and then positive and negative. On the other one the blue goes directly to the light and the black to the white plastic connector (ground?)
Box says 01-03 sdn...is that a problem? Pretty much, auction says no returns. What should I do??? Sorry for being such a newb guys. Later
hope this makes sense
Old Dec 12, 2006 | 09:55 AM
TURBOED93's Avatar
Default RE: Installing headlights, need help FAST!
theres not much for you to do
Old Dec 12, 2006 | 12:43 PM
gin0o0o's Avatar
Great help turbo. But anyway.
If the box says 01-03 sedan and you have a couple you basically bought the wrong fitment headlights. I don't think you can swap couupes and sedan headlights. Correct me if I'm mistaken. Everything should be plug and play.
Old Dec 12, 2006 | 11:08 PM
POLYTHING's Avatar
everything should come together as the universe is in harmony.
should be good bro!
Old Dec 13, 2006 | 06:42 PM
armyg316's Avatar
got these installed finally. Had another go wrong though...posted in the correct section
TunerShark
Sep 23, 2006 05:27 PM
neshlax3
Aug 26, 2006 02:46 PM
Msjessica
Dec 10, 2005 08:47 PM
89civiclx
Feb 10, 2005 12:50 PM
the_reptilian
Jan 16, 2005 05:15 PM
