JDM foglights vs. Domestic wiring harness !! added Pictures !!
Old Dec 1, 2006 | 03:20 AM
txedomask433's Avatar
Default JDM foglights vs. Domestic wiring harness !! added Pictures !!
I'm totally stcuk right now. Is there a difference b/w the wiring harnesses from a JDM set of fog lights compared to the wiring harness of the domestic set of fog lights. It's for an EK. Please help as I am stuck.
Old Dec 2, 2006 | 05:26 PM
Default RE: JDM foglight wiring hirness vs. Domestic foglight wiring harness
please help! [>:]
Old Dec 2, 2006 | 05:33 PM
Ej1Rider's Avatar
im not sure if there is not, but i would think not .... but if there is why dont you just wire it to the oem fog harness??
Old Dec 2, 2006 | 05:37 PM
riceburner700's Avatar
do you have a picture of the domestic ones and one of the jdm's?
Old Dec 2, 2006 | 07:08 PM
ok, i found out that there the same but now i have this other problem. There's this one white wire with a one brown pin connector where I have no idea where it's suppossed to go?
Old Dec 3, 2006 | 01:02 AM
jimijam's Avatar
Just got done hooking up a set of honda lights (with honda harness) on mine. If the pin connector looks like a T inside and comes off the the harness inside the car along with the switch, ground, and power wire..........that plug goes into the fuse box just above the fuses. I put mine in the slot to the left of fuse puller, but I think there were three or four of them open.
Old Dec 3, 2006 | 05:44 AM
Thanks for the tip. I plugged it in there and everything is ok now. The biggest problem came when I had everything hooked up but they didn't come on. I found out that I grounded the fog light harness to the wrong part of the engine body ;D Once I grounded it to the correct location, I switched on the fogs, and they immediatley turned on!!! I was sooo happy. I was running around for hours figuring out what I could've done wrong and it ended up being this little grounding wire, gaa! I'll post some pictures of the install and final product. the're yellow btw !
Old Dec 3, 2006 | 12:33 PM
jimijam's Avatar
I popped 4 fuses before I found out a wire was pinched behind a light and the mounting bracket.
Old Dec 4, 2006 | 05:02 PM
ej6buddy's Avatar
Here are some directions that came with mine, just for future reference in case something happens:
Old Dec 6, 2006 | 02:58 PM
Here are some pictures of the install and the final product ;D Sorry for the low quality.
W/ the bumper off
Inside of bumper with the fogs turned on after realizing that i put the darn grounding wire
in the wrong spot ;D
Wiring harnesses of death, underneath the steering wheel
Toggle switch
In parking lot lights
Artisticish shot
One of them, kinda blurry
Shbek
Feb 13, 2008 12:52 PM
mcmichael13
44
Dec 4, 2006 10:22 AM
riley32305
14
Mar 1, 2006 06:27 PM
ahhsimon
Feb 26, 2006 10:13 PM
ahhsimon
Feb 25, 2006 07:40 PM
