Leaking Trunk
Old Feb 3, 2008 | 10:18 AM
germancivic's Avatar
Default Leaking Trunk
Hey guys I have a bone stock 96 civic. MY retrunk leaks liek crazy i inspected the rubber seal and it looked fine its on the driver side i dont use the trunk at all right ow cause every time it rains i get my stuff wet. Any ideas are relly appreciated thanks guys.
Old Feb 3, 2008 | 10:23 AM
raz's Avatar
raz
Default RE: Leaking Trunk
was your car ever in a wreck in the rear of it? if so trunk may be slightly misaligned? if so take to body shop should be more than 80 bucks to fix.
u may be able to do this yourself tho also..i just dont know how or id tell ya
Old Feb 3, 2008 | 10:29 AM
Yeah it has been in a accident . Hmm anyone have ideas on how i can fix it ? t?
Old Feb 3, 2008 | 10:33 AM
raz's Avatar
raz
i would run by and get a quick estimate on it. I mean it could be a simple fix, but then there also could be some frame dmg on it from the accidcent.. if so you have no choice but take it into the shop
Old Feb 3, 2008 | 11:24 AM
Luke_Jones's Avatar
Mine has never been in a wreck and my trunk leaks pretty bad too. I havent looked into it yet, but in my experience the majority of trunk leaks come from the taillights (or the lousy seal around them). Any water that would come in around the top of teh trunk...with a seal there where is it channeled to....the taillights...so with a lousy seal behind them it usually comes in there. Another place occasionally is the drain plug under the spare tire. I'd suggest checking that plug and then pulling the taillights...if you can see that water was probably getting in through there, put a nice fat bead of silicone around it and put em back in. That's my $.02.
Old Feb 3, 2008 | 12:16 PM
well my 99 was leaking preaty bad before. it was a weak trunk seal. can you simply pull up on the trunk seal at any points? if so i would replace it and it should fix the leak. it did mine at least. tho mine was leaking from UNDER the seal and it leaked worse when i took the car thru the automatic car wash so the high pressure was forcing the water around the bottom of the seal.
but if ya dont want to buy a new OEM seal then you can always get some clear silicone and pull the seal off the car and force the clear silicone into the U grove where it goes over the metal lip and then put the seal back on, wipe off any extra silcone that may sqwirt out the sides and just close the trunk lid and let it dry.
just as good. but a new seal will be beter because the rubber is stiffer to make a beter upper seal along the trunk lid.
Old Feb 4, 2008 | 05:59 PM
dragoncivicsi's Avatar
i'm having the same problem with my trunk at the moment. except that i think water has leaket into my backseat and back carpet as well as the trunk. lately its only been the trunk though. if you have a sunroof then check the drain hoses from those. do a search and you will find more info on it.
dnspare
Sep 3, 2009 10:41 PM
boricuapr_1
Apr 12, 2009 01:38 PM
s0ulj3r
Jan 14, 2008 07:41 PM
addiction2bass
Aug 27, 2006 04:56 PM
mill$civic
Dec 13, 2005 05:36 PM
