lip kit install
Old Jul 31, 2007 | 06:22 PM
speedyturtle's Avatar
Default lip kit install
im wanting a black lip kit(front, rear and skirts) i was wondering if the install is hard or if i can do it. im a beginer.
Old Jul 31, 2007 | 06:25 PM
ej6buddy's Avatar
Default RE: lip kit install
for the front lip, it's usually just a screw in deal that can be done with a simple screwdriver. the rear is the same process, but can be a little trickier, but still easy. as for the side skirts, it depends on what you're getting, some require body work, and some require cutting and fitting. i would just suggest keeping the stock side skirts unless you're going the body kit route. (my opinion though)
Old Jul 31, 2007 | 06:26 PM
crayzieman's Avatar
Lip kits are just bolt on. If you can use a screw driver/wrench/other mechanism that turns and tightens/loosens things you can put them on.
Old Jul 31, 2007 | 07:08 PM
mill$civic's Avatar
I made a DIY in our DIY section for how to install a front lip if you want to check it out.
addiction2bass
Jul 17, 2008 12:13 AM
emooheo
Jun 16, 2006 05:05 PM
dblclutchin
May 20, 2006 12:18 PM
NCHCIVIC
Mar 24, 2006 12:57 AM
Xoopiter
Nov 3, 2005 06:12 PM
