painting valve cover
Old Jun 5, 2007 | 02:50 PM
Masonn's Avatar
Default painting valve cover
I read the post in the DIY section, but i have a couple questions first... if i take off my valve cover (on the D15B7), would it screw up anything? (like timing?) would i have to reset anything? and how hard would it be to take off and put back on? and since its the D15B7, is it an aluminum valve cover?
Old Jun 5, 2007 | 07:48 PM
riceburner700's Avatar
Default RE: painting valve cover
its not gonna screw anything up, i would recommend a new valve cover gasket though, wouldnt hurt and a decent one is like 15 bucks
Old Jun 5, 2007 | 08:35 PM
cyberx32's Avatar
also when you tighten the screws, make sure you use a torque wrench and torque them to the right specifications
Old Jun 5, 2007 | 09:33 PM
Roadkillboy0's Avatar
i didnt have to get a new valve gasket when i did mine. and since i am under 18 im not supposed to be able to buy spray paint. but the cashier just asked what i was gonna do with high heat paint. i told him i was gonna paint my valve cover and some other little brackets and stuff. so he gave it to me then showed me his awesome subaru! it was super clean. just make sure you keep all the screws and stuff. and i used some brake cleaner to clean off my valve cover. it needs to be super clean for it to come out nice
Old Jun 5, 2007 | 10:12 PM
Masonn's Avatar
ORIGINAL: cyberx32
huh..? oh **** i dont know what that means, i just assumed i had to tighten them as far as theyl go. i should probably borrow a torque wrench from a friend, eh?
Old Jun 5, 2007 | 11:24 PM
danomatic93's Avatar
June 2010 ROTM
YES!!!! You will break the v/c bolts if you tighten them too far. I actually tightened mine just at spec and one broke (old bolt).[:@] Torque it or you'll be kicking yourself.
Oh, and one bolt was 9 bucks at the Honda stealership.
I would also suggest to get a new gasket, just follow the manual.
Old Jun 6, 2007 | 08:31 AM
iv broke/stripped one and thank god i have more of them
Old Jun 6, 2007 | 01:56 PM
Masonn's Avatar
ORIGINAL: danomatic93
haha. stealership.. true.
uh, so today i was shopping for paint... and i asked the guy behind the counter of partsourcewhat paint i should buy... he asked me what temperature painti needed.. i couldnt give him an answer... what sort of temp rating does my engine paint need to be? the choices are 500 degreemotor paint, 900 degreebrake caliper paint, or 1500 degree paint. the thing is... theres only black and dull silver colours in the 1500 degree paint.. the caliper paint has more decent choices, but the colour I want is in the 500 degree paint... this is why im curious, lol so what temperature paint should i get?
Old Jun 6, 2007 | 02:01 PM
500 degree paint will be fine. i would hate to see an engine that got close to 500 degrees.[] the exhaust thats a different story
Old Jun 6, 2007 | 02:36 PM
ej6buddy's Avatar
yeah, you can almost barely cook an egg on a vc (and no, i haven't tried it and do not endorse it either)
