steering wheel removal
Old Nov 25, 2006 | 01:14 PM
rojapar's Avatar
Default steering wheel removal
i have a '99 DX hatchback and the steering wheel has an airbag. i ordered a momo steering wheel that should be here sometime next week. does anyone know how to remove the old steering wheel and what to do about the airbag issue. do you unplug the airbag and keep it in place, or do you completely remove it. will it throw a cel code of removed.
thanks in advanced
Old Nov 25, 2006 | 03:05 PM
Mr Mobsta Man's Avatar
Default RE: steering wheel removal
You have to disable your airbag first. Did you buy a hub with your wheel? And I don't think it will throw a cel.
Old Nov 25, 2006 | 03:23 PM
rojapar's Avatar
yes, i bought the hub adapter...just wondering what all was involved with removing the old wheel. i know i have to unhook the battery first, but after that, do i peel the plastic face plate off the steering wheel to get to the air bag and nut that hold the wheel to the steering column? dont really know where to start unless the new wheel comes with instructions on how to remove the old wheel, which i am doubting it does since it is prob a universal application.
thanks
Old Nov 25, 2006 | 05:31 PM
Pay a shop to do it, the air bag could kill you if you mess up. If you still don't want to listen to me then go to Advance Auto Parts and buy a haynes manual and it has step by step of how to disable your airbag and take the wheel off.
Old Nov 25, 2006 | 08:41 PM
SPLAT's Avatar
Becareful, the air bag can still go off even with the batt removed. Not only coud it kill you but give u some bat burns, Good luck with it though.
Old Nov 25, 2006 | 08:44 PM
If it kills you I don't think you would be worried about getting burnt.
Old Nov 26, 2006 | 11:26 AM
absoulute's Avatar
yea be careful cause the bag can still go off. but here is what u want to do look on the back of the wheel there is a couple of plastic tabs that come out and then u can get to the bolts that hold the airbag on .. do not remove the plastic covering on the front of the bag . after u remove those bolts u can pull it out then u will have to unplug it this is when u don't want to be in front of it. then there is this wire thing that gives the airbag power it looks like a spool so when u turn the wire doesn't get tangled. then u will see the big nut and u probably need a steering wheel puller i did atleast there like 10 bucks at autozone. but i throw my airbag light now i removed both of them. be careful and have fun
Old Nov 30, 2006 | 11:41 AM
tonejunkie's Avatar
Not to hijack your thread, but let me know how that goes.
It may sound crazy but I'd actually like to do the opposite. I've got a 4th gen hatchback and I'll be driving alot of highway miles next year(2 hour commute). Has anyone tried adding an airbag to a honda that didn't have one to start out with? Would I have to wire up anything other than a bumper sensor and a speed sensor? Is this even safe? I feel comfortable with electronics but with exploding bags--now that I am not so familiar with....
Thoughts, anyone?
Thanx
Old Dec 4, 2006 | 12:19 PM
Briscivic's Avatar
I read in this customizing book you can get styling rings to go around the wheel... but doesn't cover the centre air bag. I've tried searching thru ebay but haven't had any luck. Anyone seen any of these advertised??? apparently you just stick it onto ur wheel... they come in woodgrain/ carbon fibre etc.
Old Dec 4, 2006 | 06:02 PM
lol do u mean a wheel cover?
3cylindercivic
Aug 29, 2009 08:25 AM
jpnolan
Apr 14, 2009 11:11 AM
zerojett
Jan 21, 2009 05:26 PM
Everyday Getaway
Mar 6, 2008 06:21 PM
ltkenbo
Interior DIYs
Jul 23, 2007 11:53 PM
