tint or paint my tail lights??
What's up everyone
Basically I tinted my tail light but due to all the curves and the stamped dot #'s the tint didn't look all that great on my tail lights. I did like how the tint adds the black glossy shine to the tail lights as it goes great with my paintjob but the tints don't look right on the tail lights themself (it lifted at soeme points,it didn't curve correctly on other parts)...
So basically what I'm asking is,what would or how would you guys handle this??
Tint the tail light? and if so do you have a pro do it for it and what would be the price range
Or
Do you paint them? If so what paint would u use,I would like it to have the same glossy/shiny effect that the tint has if possible.
But thanks every1 for reading and any advice,
Or
i got some tint off ebay like $15 it turnd out good. IT wasint sticky on one side, i just used sticker on, and moved it in place and it holds up to car wash. And its easy to peel off if you want to remove it. not shore if you can re use it after. I also have blue tint for the front head lights, that is sticky on one side. i havint put it on yet.
Let me know if you want to know the seller. the rear was $15 and front was like $25.
i would paint them instead of using tint film. VHT Nightshade is an excellent paint to use. if it's done right it will give you the gloosy look. more durable and easier to do than tint. a couple of members on here has use VHT and came out great.
thanks for the response everyone, so basically buy the vht and sand the lights lightly,clean good and add a couple of light coats right? (i read some of the other post )
the only thing im scared of if it would come out like a flat black,or i would deff need a can of clear coat ??
And the paint itself is a mid-gloss paint, but it depends on the lens color; for example, my tails are flat black since the taillights were red, but my headlights are semi-gloss because the lenses were clear. If you want it super glossy, just find some good gloss clear and give the lights a few coats of clearcoat.
Just the info i was looking for, thanks, so just to get it stright,
just buy the vht paint, remove the headlight/ tail lights and give them a good scrub w/ 1000g sandpaperand clean really good,
next spray a couple of light coats on the headlights/ tail light untill you like and put back on the car and enjoy,if there not too glossy then get a good gloss and add a couple of light coats
to remove the vht paint just sand off with what 1000g sand paper and buff out like you would a car??
but again thanks for the info man, it was great,btw im i on the path...
