Valve Cover Mod
Old Sep 3, 2005 | 05:47 PM
  #61
2000Ex's Avatar
Default RE: Valve Cover Mod
I have a question. Will I have to replace a gasket so that I get a good seal when i put the valve cover back on. Someone mentioned it at Autozone and I thought since noone has said anything I wouldn't need one.
Old Sep 3, 2005 | 05:52 PM
  #62
ngoti 8tor's Avatar
ORIGINAL: 2000Ex
Yes, Don't reuse the old one.
Old Sep 3, 2005 | 05:54 PM
  #63
2000Ex's Avatar
Where can I pick one up and this should def be in the DIY. Noone wants to leak oil.
Old Sep 3, 2005 | 06:16 PM
  #64
ngoti 8tor's Avatar
ORIGINAL: 2000Ex
You got a Pepboys where you're located? Any parts store should have em, hell it's a Civic we're talkin about.
Yes, it should be in the DIY to replace the gasket.
Old Sep 3, 2005 | 06:29 PM
  #65
2000Ex's Avatar
Now I know I am starting toget noobish but how much does one of these costs. And is I am not mistaking these guys haven't been replacing theirs..
Old Sep 3, 2005 | 06:35 PM
  #66
ngoti 8tor's Avatar
ORIGINAL: 2000Ex
Not sure how much, but I wouldn't think they're that much. Anything under $20 would be well worth it. And yes, they shoulda replaced theirs, maybe (no, hopefully), they just forgot to mention it.
Old Sep 3, 2005 | 07:45 PM
  #67
StifflersMom's Avatar
Cat Fuсker
You only have to replace that gasket if its detiriorated. It's a piece of rubber...although I used some copper gasket maker on the side just to be safe.
Old Sep 3, 2005 | 08:22 PM
  #68
2000Ex's Avatar
So I guess I won't buy one and only go out and get one if it is in bad shape. Sound like a plan? Also the only clear coat I could find that was hi-temp had ceramic written on it. Should I use it or get a different kind.
Old Sep 4, 2005 | 01:30 AM
  #69
ngoti 8tor's Avatar
ORIGINAL: 2000Ex
Bad news! You'll wish you would have replaced it with a new gasket, especially for the price.
Old Sep 4, 2005 | 11:13 AM
  #70
Cat Fuсker
It's a valve cover gasket...it's rubber, and it'll only leak in two cases: 1). Its detiriorated, 2). You're an a$$ and didn't tighten the bolts to the correct torque or tightened the bolts not in a criss-cross pattern...
