DC Sports 4-2-1 Ceramic
Old Jul 13, 2006 | 12:29 PM
Chimera02EX's Avatar
Default RE: DC Sports 4-2-1 Ceramic
Not adjustable, the simulator sends the ECU the signal it's expecting for normal operating conditions no matter what the O2 sensor is attempting to send to the ECU. If you have a CEL it's the only way I know of to fix it; do you need plug n play... no but it makes it a hell of a lot easier to install and the simulator I suggested above is a quality sensor, you won't be replacing it after a month.
Old Jul 14, 2006 | 09:55 PM
pWnEdU's Avatar
I see... so you need that if your oem sensor is not responding well to the header... Do they all do this?
That would make me nervouse though, completely bypassing the o2 sensor like that. I wouldn't do that without an A/F or EGT gauge.
Old Jul 15, 2006 | 07:12 AM
rdss's Avatar
I think by passing the after cat O2 sensor is only bad if you still have a cat in it. If the test pipe has not catalyst in it there is nothing to fail or clog.
Old Jul 15, 2006 | 08:29 AM
Most headers will do this, an A/F gauge in uneccesary, and if the cat fails, you'll know it. The after-cat O2 sensor does nothing but tell the ECU that there is no problem with the cat. It does not affect your A/F ratio.
Old Jul 15, 2006 | 09:38 AM
pWnEdU's Avatar
Oh ok. Thanks for the info.
Old Aug 29, 2007 | 08:03 PM
muttmuzik's Avatar
i'm actually thinking about getting these headers. and im pretty new to this forum stuff so i dont even know if im allowed to ask questions here but: do the headers come with any other things? do i need to get a new gasket? or nuts and bolts? i have an '03 EX coupe.
Old Aug 29, 2007 | 11:14 PM
TheMoogly's Avatar
This is PRODUCT REVIEW not intake/HEADER/exhaust section... but you can use your factory gasket most of the time
Old Aug 30, 2007 | 06:50 PM
tknaub's Avatar
PWNED!
Old Aug 30, 2007 | 10:36 PM
TheMoogly's Avatar
I throw CELs all the freaking time... it goes away after an hour or so, but it drives me nuts sometimes... does it especially if I put higher than 89 octane gas in my car for some reason.
mahlum
Jul 31, 2007 06:03 PM
xkeseriesi
May 22, 2007 03:28 PM
NonTurbo4now22
54
Jan 8, 2007 12:30 PM
mhayes2344
Aug 9, 2006 11:09 PM
D16z6
Dec 21, 2004 09:04 PM
