Weird Problem
Old Mar 16, 2006 | 10:20 AM
Pete's Avatar
Default Weird Problem
Today I go to start my car........Running ROUGH! Its like sputtering down the road....then just dies. I try to start it and NOTHING. I pull it over, pop the hood, everthing looked good, nothing major. Then I get back in the car, pump the gas petal, and it starts up fine, runs normal? Any ideas? Air in gas line? Bad fuel? Ive got no clue.
Old Mar 16, 2006 | 10:30 AM
Talon585's Avatar
Default RE: Weird Problem
I had a problem similar to that in my dads blazer. It turned out that the fuel pump was starting to die. For some reason i had to let it sit for half an hour then it would start up right away.
Old Mar 16, 2006 | 10:31 AM
jake11375's Avatar
Sounds like the engine coil. When mine went out I could have sworn from the symptoms (sputtering etc.) it revolved around the fuel system, but come to find out it was the coil. Best of luck getting it fixed.
Old Mar 16, 2006 | 10:34 AM
Pete's Avatar
I Have a brand new honda coil.
andryuha's Avatar
I don't think Civics have coils. They use a distributor and regular wires.
BTW, your problem sounds lie a furl delivery problem. Since you have FI, I take it that you are using an adjustable fuel regulator. Maybe it's out of whack? What is your F/A gauge showing (i assume you have one)?
Old Mar 16, 2006 | 01:37 PM
natecivic92's Avatar
Sounds to me like it is the fuel pump.I normal would put a fuel pressure tester on it and start the car and let it idle till it does it.Or you can wait till it just dont start.
Old Mar 16, 2006 | 01:43 PM
jake11375's Avatar
a.k.a. ingition coil. I've mostly heard them referred to as engine coils.
Old Mar 16, 2006 | 02:11 PM
Pete's Avatar
It was running normal the second time too.......I dont know. I sure hope it starts up now......I gotta go to work...maybe ill order a new fuel pump.....well see. Anyone else?
Old Mar 16, 2006 | 02:19 PM
riceburner700's Avatar
the way to tell if a fuel pump is going bad is to listen to it while its running, it will get really loud and them adventualy just give out... Try a fuel pressure test they are very simple!
xypher
Dec 4, 2005 04:28 PM
sindiesel666
Sep 19, 2005 08:28 AM
vmf
Jul 25, 2005 10:44 PM
AnakinKenobe
Jun 20, 2005 10:55 PM
civicgolg
May 24, 2005 04:13 PM
