01 DX engine jitter in hot weather
Old Jul 12, 2009 | 04:29 PM
biocpu's Avatar
Default engine jitter in hot weather
I am in LA. In summer hot weather (above 80deg), whenever braking to stop, the engine jitters (but not yet stops). But at night or in winter time, this problem does not occur. So during the day it jitters but not at night.
Last summer I took the car to honda dealer because of this problem. They said normal after checking computer.
Never performed tune up. Airfilter replaced recently with ...Fram... filter.
Old Jul 12, 2009 | 04:44 PM
kdubbla's Avatar
Default yo
my civic does this too, my idle air control valve is the reason, my motor too has 40k miles im not worried about it, you should hear my bro's accord UP DOWN UP DOWN UP DOWN very irritating but fine
Old Jul 13, 2009 | 04:55 PM
kdubbla's Avatar
Default yo
ok i looked it up in the snap-on scanner today. did you recently adjust your valve lash? says that may be the cause and its too tight, or your distributor if labeled TEC is may be going bad
Old Jul 13, 2009 | 05:08 PM
Replace the spark plugs and clean the throttle body.
Old Jul 13, 2009 | 09:18 PM
Originally Posted by biocpu
sure.. spark plug is the first to check. but isn't it supposed to last for ~100k miles?
No, they should be replaced every 20-30K miles.
mocivicman
Jan 2, 2011 09:13 PM
biocpu
Jun 29, 2007 11:29 PM
jeff716a
Jul 31, 2006 07:41 AM
rikstaker
Jul 11, 2006 06:38 PM
raphn
Jun 14, 2004 02:07 PM
