03 civic idle issues
Old Aug 14, 2010 | 04:49 AM
fixnfly's Avatar
Default 03 civic idle issues
Hi, long time lurker with a problem that I just can't figure out
Bone stock 03 civic DX 130,000 miles
Within 1-2 minutes after start up on a cold engine, the idle will slowly drop to a point where the engine is just barely running. It will run like this for about 20-30 seconds and then the rpms come back up and it runs like nothing ever happened. It only happens occasionally but when it does, it's always within the first 2 minutes after startup as if it is on a timer. If I shut the car off while it's bogging down, it starts right back up and runs fine. There are no codes.
Things I have tried...
cleaned IAC valve and throttle body
checked pcv valve
checked for vacuum leaks
sea foam
plugs and fuel filter are new
Any ideas would be greatly appreciated!
That Painter Guy LLC
18
Oct 19, 2013 02:35 PM
civicsrus
Feb 4, 2012 12:17 PM
skipstruckandcarwash
Apr 26, 2011 01:02 PM
93b18civic
Feb 14, 2011 01:57 PM
wes
Oct 5, 2009 08:38 AM
