03 Civic keeps overheating
Old Jul 23, 2019 | 06:13 AM
stglove27's Avatar
Default 03 Civic keeps overheating
I have an 03 civic that keeps running hot. Ive replaced the radiator, water pump, timing, hoses, thermostat (Honda oem), radiator cap. i could drive hours around my city with no problem. BTW its summer time heat down in South Ga. but i can drive around with no issues. soon as i get on the interstate and drive out about 15 or 20 miles out. my temp hand moves up and down bouncing between halfway and up to the H (red lines). if i stop it will run completely hot. the mechanic i took the car too check the head-gasket and said it was good.
seems like the car only runs hot when driving far out
Old Jul 24, 2019 | 03:28 AM
StifflersMom's Avatar
Cat Fuсker
Have you made sure the fan actually runs on both low and high speeds properly?
Old Jul 24, 2019 | 04:22 AM
stglove27's Avatar
Found out it may be the fans. the car ran hot again yesterday. once i cut the car off, i noticed the fans wasn't running but after the temp hand dropped down a little the fans would cut back on and finish cooling the car back down.
EllieChameleon
Jun 23, 2012 07:28 AM
ianer167
Mar 16, 2012 04:42 PM
jonsaidthat
Aug 1, 2011 08:06 PM
runninghot
May 15, 2009 06:09 AM
blk_blazer
Aug 10, 2007 03:17 PM
