03 EX shifting probelms
Old Apr 10, 2010 | 05:57 AM
ashleighx0's Avatar
Default 03 EX shifting probelms
Hey everyone. I have a 2003 Honda Civic EX has about 95k on it. Seems to not be shifting perfectly, at first I guess I thought it was normal, going from a Ford to a Honda, it was just different, but now I know something is wrong. When I go from a stopped position, sometimes, not all the time, going into 1st, 2nd, and 3rd gear, it sounds like it goes into neutral and THEN goes into gear, like its falling out of gear or something. It happens alot with the 3rd gear, but it doesn't happen all the time. Any suggestions on how to fix or find out the problem? I had a transmission flush done to it, and that did not work. Thanks guys.
Old Apr 10, 2010 | 02:51 PM
tonyhatchetman's Avatar
ive read about changing some or all of the solenoids but i dont know witch one ........and also is the temp of the engine getting up to normal i had some problems with that and the guys here told to check that and so i did and changed the thermostat to the right one and fixed it ,...............good luck
Old Apr 10, 2010 | 07:00 PM
ashleighx0's Avatar
Thanks. And yes it seems that my temp is good.....how many solenoids are there?
Old Apr 11, 2010 | 05:22 AM
mine has 2 locking 2 shifting and 1 linear,............im not to sure what they do and witch one you should change ...............maybe some here will know ,.......good luck
Old Apr 11, 2010 | 07:05 AM
ashleighx0's Avatar
thanks, anyone else have any other ideas?
Old Apr 14, 2010 | 03:18 PM
ashleighx0's Avatar
please? any thoughts would help
Old Apr 25, 2010 | 06:44 PM
ashleighx0's Avatar
here is a video of it shifting. any thoughts?
http://www.youtube.com/watch?v=-UVZwGH8eXc
Old Apr 29, 2010 | 01:49 PM
runrider's Avatar
are you pressing evenly on the pedal, or are you moving the gas up and down as you accellerate?
Old Apr 29, 2010 | 02:06 PM
ashleighx0's Avatar
i'm pressing evenly....it happens every time i drive.....
kevin_405
Nov 2, 2010 05:54 PM
ImportTrendz
May 23, 2007 08:36 PM
fast93civic
Mar 22, 2005 01:43 PM
Narcoleptic724
Dec 3, 2004 08:58 AM
kobejelbryant8
Jul 15, 2004 08:31 PM
