04 civic check engine no tack intermittently no communication
Old Nov 14, 2008 | 12:13 PM
civic2004's Avatar
Default 04 civic check engine no tack intermittently no communication
04 civic 1.7 manual
Started with alternator slipping, snapped bolt on alternator clean off.
Theft light flashing, no communication with computer.
Checked out at my mechanic shop with no luck then scanned at honda with the honda scan tool, they say bad ecu is tip of the iceburg($1000.00+), took it back to my mechanic and on drive theft stopped flashing, check engine light was turning off intermittently(not flashing) tack would come on whenever engine light shut off.(relay under glovebox clicking).
Bad relay?
Could car starter cause these problems?
Bad ECU????
NE help gr8tly appr.
Old Nov 14, 2008 | 12:30 PM
315 Customs's Avatar
Please do not double post as it is against the rules.
If it is a bad ECU then that is covered by a federal emissions warranty of 8 years or 80,000 miles and Honda has to replace it free of charge for you if you are under 80,000 miles.
Old Nov 14, 2008 | 01:32 PM
civic2004's Avatar
sorry about that I didn't know,
Do you know if that applies to Canada?
Old Nov 14, 2008 | 03:02 PM
Look for fundamental electrical problems like the battery connections and all ground wires. The computers will go haywire when they don't get steady power. I don't know if the theft light is tied into the ECU or not. Can you link to the ECU when the tach is working and the CEL is out?
Old Nov 14, 2008 | 04:07 PM
civic2004's Avatar
only works for a second so no communication checked fuses wires grounds
Old Nov 14, 2008 | 06:25 PM
hey I'm not sure if it applies to Canada as well or not
PCollen
Jul 8, 2014 07:09 AM
downshift
May 10, 2013 03:59 AM
LoungeLover
Oct 23, 2011 10:31 PM
PedersonHondauser
Aug 31, 2011 01:43 PM
