04 Civic. No air coming through vents.
Old Feb 5, 2012 | 06:30 AM
pensacolairish's Avatar
Default 04 Civic. No air coming through vents.
Hello folks, had the shop look at it yesterday and was informed it would be best to take it to the dealer. Said they tried a different blower motor and that wasn't the issue. Basically my problem is no air whatsoever, hot or cold flowing through the vents, as of from friday. Any idea what it might be, rough cost? I have no technical knowledge of cars I might add.
Old Feb 5, 2012 | 06:34 AM
Usually the problem is the power transistor. With everything plugged in, turn key on and switch on high. Then measure voltage from each motor lead to ground.
Zero volts on both: No power from the fuse or relay. Those are both in the fuse box under the hood.
12 volts on one, zero on the other: The motor is getting power. If it doesn't run, bad motor.
12 volts on both: Bad power transistor or (very rarely) the control panel. There is a control panel self-test but I don't remember how to do it. If other functions of the panel work (you hear motors running when you turn the air selector), it's pretty safe to just replace the power transistor.
The power transistor is mounted to the ductwork behind the glove box. Some parts houses still call it a "blower resistor" even though it is actually a transistor in later models.
Old Feb 6, 2012 | 05:00 PM
Thanks mk, any idea of cost of repair/replace?
Old Feb 6, 2012 | 06:22 PM
The power transistor is somewhere between $50.00 and $75.00 for the part. Labor is minimal.
sillysef
Apr 28, 2011 03:51 PM
fawright
Oct 26, 2010 04:04 AM
bko62
Apr 14, 2008 06:34 AM
Accountant30339
19
Sep 12, 2007 10:01 PM
Shandles
Sep 2, 2005 04:05 PM
