1.5 Overheating
Old Sep 11, 2011 | 09:55 AM
stungbug's Avatar
Default 1.5 Overheating
Have a 1990 1.5 Hatch completely stock. Overheats only when outside temp is warm and climbing hills. Fan working, new thermostat, no coolant loss, system bled, new radiator cap, great gas milage and runs fine otherwise. Cleaned outside of radiator to get rid of all the bugs.
Any ideas?
Old Sep 11, 2011 | 10:25 AM
tonyhatchetman's Avatar
head gasket ? Radiator clogged inturnally ?
I had this problem kinda when it was hot out and I lugged the motor down the temp would rise and changed the radiator and fix it ....but it could be the head gasket. Or?
Old Sep 11, 2011 | 10:53 AM
stungbug's Avatar
I am leaning toward internal radiator. It doesn't act like a bad head gasket or water pump
Old Sep 11, 2011 | 12:56 PM
Mecca8383's Avatar
I'm having the same issue as well in my 92 LX. Changed everything you said and the radiator....still overheats...I'm about to replace the head gasket but there are no signs of a gasket leak(no white smoke, no bubbles in coolant, no coolant lost).
Old Sep 12, 2011 | 08:17 AM
droopy128's Avatar
Probably internal, I have a radiator you can try if you in my area.
trebor_2005
May 19, 2006 01:40 AM
Wooz
Apr 26, 2005 10:04 AM
9toes
Jan 28, 2005 01:43 PM
sonscivic
Jan 4, 2005 06:16 PM
Civic95Blue
Jul 29, 2004 10:09 PM
