1.7 Honda Civic No Start (Has fuel, spark, compression)
Old Aug 29, 2019 | 01:45 PM
Thomas McKinley's Avatar
Default 1.7 Honda Civic No Start (Has fuel, spark, compression)
2002 Honda Civic 1.7 liter.
I was driving down the road and got cut off and had to come to a hard stop. The car stalled and wouldn't retstart. Towed it home. Tried to jump start it going down a hill. Sprayed starting fluid into the intake. Didnt even sputter. Pulled a coil injector and got good spark. Compression is around 160 in all 4 cylinders. Timing belt isn't broken. Can see the rods lifting when cranking though the oil fill. Thinking maybe the cam shaft sensor or crank shaft sensor. Really dont want to pull it all apart if there's a better explanation or a way to rule them out without tearing it down. It isnt throwing any fault codes either. Any suggestions? Please help...
Old Aug 30, 2019 | 09:28 AM
StifflersMom's Avatar
Cat Fuсker
You're looking in the right directing. Other than fuel, spart and compression you need timing (ignition and cam). Timing belt could be good but could jump a few teeth, that does happen fairly often. Cam and Crank sensors are also good places to start. I'd grab a timing light and start from there.
Old Aug 30, 2019 | 06:43 PM
You were right. Jumped some teeth. Running like new… well for a 2002 with 215,000 miles at least.
jcodysmith
May 1, 2010 07:11 AM
jdbe
Jan 3, 2009 02:55 AM
bobbed83toy
15
Sep 28, 2008 10:06 AM
pp_MR2
May 10, 2007 03:44 PM
BrianT
14
Apr 17, 2007 04:04 PM
