1990 civic Speedo troubles
Old Mar 12, 2010 | 07:32 AM
BcBaudoux's Avatar
Default 1990 civic Speedo troubles
Had a friend help rebuild bottom half of motor (d15b8). Put motor back in, all's running good except my speedometer is not working right. The tachomotor works. Any sugestions or woords of advice would be a awsome. thanks
Old Mar 12, 2010 | 07:36 AM
Have you checked the speedo cable? Did you reconnect it?
Old Mar 12, 2010 | 07:38 AM
BcBaudoux's Avatar
yes i did but it jumps around and dosent go past 20mph
Old Mar 12, 2010 | 07:43 AM
Inspect the ends of the cable at the transmission and speedo and also test the speedo:
Old Mar 12, 2010 | 08:02 AM
You can detach the cable from the transmission and pull the center part out. Make sure it is intact, it should be ground down into a square on the end that goes into the speedometer. Apply grease to the cable and reinstall.
Look into the socket on the transmission to see where the slot is. Before inserting the cable, rotate it to align the tab on the end with the slot. If you have it too far off it will not go in all the way.
Old Mar 12, 2010 | 08:26 AM
BcBaudoux's Avatar
thanks alot guys i got it to work i aprecatie your help
mathewkozak
Jun 9, 2008 01:21 PM
Djohnsto
Mar 6, 2006 06:28 PM
Drifter721
Dec 15, 2005 01:31 PM
903door
Nov 1, 2005 01:06 AM
Readyforthepasture?
Nov 6, 2004 09:57 AM
