1994 Civic Starting Problems
Old Feb 2, 2007 | 05:44 PM
civichonda1994tampa's Avatar
Default 1994 Civic Starting Problems
All,
I hope you can help me. When starting my Civic today, it would not turn over, from what I know the starter sounded fine, and as it usually does before turning over. It took me six times turning the key before the engine turned on. After driving for 6 miles I stopped and turned the car off, and it turned on fine after that. Then after letting the car sit for 8 hours, it did the same thing again, and didn't want to turn over. From the sound, it sounds like the iginition and starter are fine but what do I know.
Your help is appreciated.
R.
Old Feb 2, 2007 | 08:04 PM
kinosh's Avatar
Default RE: 1994 Civic Starting Problems
I'm confused. If the engine doesn't turn over, it could be the starter. If it turns over, but doesn't start, it could be the ignition system, a fuel line issue, or the main relay.
Old Feb 3, 2007 | 08:38 AM
jake11375's Avatar
Check your distributor along with the other things kinosh mentioned. Good luck.
Old Feb 3, 2007 | 01:47 PM
fglaustin's Avatar
when one says that it turns over, that means that the starter and battery are good and the engine is cranking
Chopin
May 14, 2013 04:29 AM
Toolmaker1
May 25, 2010 09:53 AM
eddy_7
Feb 26, 2008 02:55 AM
nramil
Sep 4, 2007 11:08 AM
totenkopf
May 31, 2007 03:36 PM
