1994 Civic starting problems
Old May 25, 2010 | 08:34 AM
Toolmaker1's Avatar
Default 1994 Civic starting problems
I have a 94 Civic EX that won't start when the outside temperature gets above 70 degrees, I live in Ohio so this just started I have been able to get it started on other warm days with a couple shots of starting fluid so I know it is getting spark it seems to be a fuel issue, is there any help anyone can give on this matter
Old May 25, 2010 | 08:38 AM
If the fuel pump fails to prime when the engine won't start, then resolder the main relay.
http://techauto.awardspace.com/mainrelay.html
Old May 25, 2010 | 09:25 AM
It's common for a bad main relay to do that when it gets warm. The relay is located on the side of the car under the dash, above the lever you pull to open the hood.
Old May 25, 2010 | 09:49 AM
Infinitrium's Avatar
I had a 92 Accord that had occasional warm starting trouble caused by a relay problem. Swapped the relay with one from an automatic (mine was a manual) and it worked fine after that.
Old May 25, 2010 | 09:53 AM
Toolmaker1's Avatar
Can u buy a new one and about how much is it?
Chopin
May 14, 2013 04:29 AM
eddy_7
Feb 26, 2008 02:55 AM
nramil
Sep 4, 2007 11:08 AM
totenkopf
May 31, 2007 03:36 PM
civichonda1994tampa
Feb 3, 2007 01:47 PM
