1996 DX O2 Sensor Question
I have a 1996 Civic DX w/ a manual tranny. The oxygen sensor is bad and I need to get a new one in order for it to pass the smog check so I can sell the car. I have called about a dozen places and the cheapest O2 Sensor I can get for that year and model is like 450 bucks. I am wondering if an oxygen sensor from an older year (hopefully cheaper) would work with my car and make the check engine light go off.
$70 bosch universal will work, you'd just have to connect the wires properly... your o2 sensor is a 4 wire heated sensor, so make sure to get the right one.
note that your car has two o2 sensors, one upstream, and one downstream of the catalytic converter, and it will still throw a cel if you replace the wrong one.
Also, the secondary one (downstream) in the DX tends to rust into the end of the catalytic converter pretty solid, so they might be quoting you $400 figuring they'll have to replace it
anything more than $150 for an o2 sensor would be unusually high
addiction2bass
Aug 14, 2008 09:53 PM
fglaustin
Mar 27, 2008 08:29 PM
Vox1
Oct 14, 2007 12:29 PM
00sithrottle
May 12, 2005 10:25 AM
