1997 Honda Civic DX popping noise drivers side
Old Apr 20, 2013 | 02:31 PM
Tommyboy1's Avatar
Default 1997 Honda Civic DX popping noise drivers side
Hi!
I could use a little guidance...
I have a 1997 civic DX and was having a problem with a drivers side popping noise when I would pull into a parking spots...
So it would be at low speeds and I would turn into a parking spot...pop pop...then straighten the wheel and I would hear just a pop. It wouldn't happen all the time just occasionally.
I did a little research and thought like many who post and get responses, it's gotta be the CV axle. I inspected the axle and indeed the boot was thrashed but had some grease left. I figured sweet, easy fix...
Replaced the axle and low and behold the popping is still there.
Trying to do a little more research now instead of just guessing...
So at an idle just sitting I turn the wheel back and forth all the way and I get the pop pop sound, I believe I have the noise dialed down to the driver side but I am stumped on what it is??? Ball joint...strut...tie rod end.
Maybe somebody can point me in the right direction...
Thanks so much in advance
Old Apr 21, 2013 | 04:34 AM
Have someone else turn the wheel while you listen outside the car to find out exactly where the noise is coming from.
puddyguy
Oct 23, 2014 02:23 PM
electricjw
Aug 30, 2014 06:57 AM
Tommyboy1
Apr 20, 2013 02:23 PM
celestialwolven
Feb 26, 2011 07:34 AM
Fiirkan
May 8, 2006 07:22 PM
