1997 Honda Civic EX Troubles
Old Apr 1, 2010 | 04:43 AM
newhondaguy's Avatar
Default 1997 Honda Civic EX Troubles
I have a 97 Honda Civic Ex and this morning I heard a wining sound and then the battery light came on and had no power steering.
The car would restart fine. 2 belts (or 1) on driver side was not turning.
Help
Old Apr 1, 2010 | 04:56 AM
tonyhatchetman's Avatar
might have came off the pullys if one was bent or some thing is loose ,..or it broke and you just cant see the end that broke ,...or something locked up ,....maybe ,...any one else have any ideas??
Old Apr 1, 2010 | 06:13 AM
Check the alternator belt. If that's fine, the alternator may have failed.
Old Apr 1, 2010 | 07:36 AM
The crank pulley may have come loose. Usually though it falls all the way off and the pulley lands on the road. Check that the crank pulley is securely bolted on. Do not drive any more while it is loose because you risk messing up the timing belt.
Old Apr 1, 2010 | 09:57 AM
That was my next question. Belt is in tack. There is a pulley that is loose and looks as if it is going to fall off. I am assuming this is bad.
Old Apr 1, 2010 | 11:08 AM
I haven't had the opportunity to look at this closely. Everything that I am reading about concerning crankshaft bolts is that they are a bear to get off. So how is it that mine just came loose? I can't imagine a bolt that strong breaking, especially with what people are doing to them just to get them loose.
Is this something I can do, as a novice, or should I take it to a shop.
Old Apr 1, 2010 | 12:37 PM
Whoever did it last probably didn't tighten it enough. As you found out, the bolt is very tight for a reason.
zrooster99
Sep 24, 2007 01:16 PM
Cody_Bell97
May 20, 2007 03:14 PM
Cody_Bell97
EK Swaps
Oct 25, 2006 09:32 PM
IamEi2907
May 19, 2006 01:16 PM
Readyforthepasture?
Nov 6, 2004 09:57 AM
