1998 honda civic doesnt crank
Old Jul 5, 2011 | 04:28 PM
EG1027's Avatar
Default 1998 honda civic doesnt crank
One day it was driving fine. Next time I went to start it and it does nothing. All the lights dash radio ect everything works. I already checked battery, starter, igniton switch, and main relay. I dont know what to do now. Anybody have any ideas where to go next or something I might be over looking??? Any help is greatly appreciated thanks
Old Jul 5, 2011 | 05:17 PM
90 Civic's Avatar
How did you check the starter? What about the solenoid? What about a loose or corroded wire.
Old Jul 5, 2011 | 06:22 PM
Did you check the clutch switch? It's common for the rubber pad to fall off the clutch arm and then the switch won't be pressed to allow starting, even though you pushed the pedal down.
Old Jul 6, 2011 | 03:10 PM
EG1027's Avatar
I brought it to advance auto parts and it turn right on. Does the soleniod get checked with that? And for the clutch switch I did find the rubber pad on the floor but doesnt that switch work the opposite way?
Old Jul 6, 2011 | 10:20 PM
90 Civic's Avatar
Smile
Yea that should of taken care of the solenoid also. So the clutch as stated maybe your issues.
Old Jul 7, 2011 | 03:23 PM
EG1027's Avatar
Update I tried jumpin the starter and the car started right up. Anyone know where i could find the starter relay?
Old Jul 7, 2011 | 08:42 PM
You may have a bad ignition switch.
thebriarman
Jan 27, 2016 11:18 AM
edwarlkd814
Mar 27, 2012 03:41 PM
zerojett
Oct 18, 2011 03:01 PM
03civex
15
Oct 28, 2008 08:20 PM
kliz
Apr 30, 2007 12:44 PM
