1999 Civic DX Window Handle
Old Jan 2, 2011 | 12:39 PM
KingDakota12's Avatar
Default 1999 Civic DX Window Handle
Well sadly being stuck with a DX means I don't have power windows and these crank downs break so much and usually I am lucky enough to glue them back on, but my driver side one broke in several pieces and needs a OEM replacement and call me crazy, but I can't find one online so If I could have a link that would be great thanks.
Old Jan 3, 2011 | 11:11 AM
mundy5's Avatar
go to a site like: hondaautomotiveparts.com and input your year and trim and look under the category of front door; it's listed as part #3 but has 2 different colors so you need to pick the correct one. Btw, there are also many other oem honda parts dealers so make sure you shop around.
Old Jan 13, 2011 | 04:14 AM
Alright found the site, but does my 2DR Civic DX have the classic gray handles or Excel Charcoal I can't tell!?
Old Jan 13, 2011 | 04:26 AM
See if interior color is listed on one of the build stickers (door jamb, glove box, or underside of the hood).
Old Jan 13, 2011 | 04:28 AM
Alright I will thanks just snowing like crazy, but I couldn't find the answer on google, but I think Classic Gray is for 2 DR's and 4DR's have Excel Charcoal, but Ill look thanks.
Old Jan 13, 2011 | 04:59 AM
Well if you end up having to guess you could buy a pair of new ones to be sure they're the same color. Then you have the old one from the passenger's door as a spare.
Old Jan 13, 2011 | 05:01 AM
Welll that's what I plan on doing because I broke my driver's side handle, it snapped off so I need to replace it, so Ill only be ordering 1 handle.
Old Jan 13, 2011 | 05:35 AM
Didn't find anything on my car, but a website said the Classic Gray was for 96-00 Civic 2 and 3DR only and the Excel Charcoal is for DX 4DR's so Im ordering from OEMUnlimitedHonda.com
Is all I need is the handle and the pin?
Old Jan 13, 2011 | 06:52 AM
Yes. I've replaced several of these. They're sort of a pain.
You'll have to put the pin on the new one so that it will pop on with a slight push (you'll know it when you see it.) Then you have to put the handle on, then push in on the door panel so you can stick some pliers or something in to push the pin down.
Old Jan 13, 2011 | 07:17 AM
Alright Thank you! Im ordering my handle and the pin now wish me luck on the install
osengj
Jul 30, 2011 09:19 PM
pjcarr
Apr 20, 2011 07:01 PM
JayVee
Jan 1, 2010 07:55 PM
Jaynik
Aug 21, 2008 04:30 AM
Poopers
Jan 2, 2006 02:42 PM
