1st gear and 2nd gear grind?
Old Apr 8, 2010 | 07:05 PM
Juans_MX3's Avatar
Default 1st gear and 2nd gear grind?
So my 5spd 95 Civic EX (coupe) has a grind like noise when i hit about 2800-3300RPMs on 1st and 2nd gear. You could kind of hear it on 3rd gear but its really noticeable on 1st and 2nd.
Sometimes in the cold morning or when I just barely started the car and start running it (without warming it up), the "grind" wont be there.
But most of the time you can hear it. However, I dont hear a grind when switching gears. Only happens from about 2800 RPMS to 3300 RPMs. Sometimes it varries.
Bad tranny?
Old Apr 8, 2010 | 10:07 PM
Does the noise go away if you press the clutch pedal down? If so, the input shaft bearing in the transmission may be shot.
Old Apr 9, 2010 | 04:48 AM
Check the fluid level first. Noise that occurs idling in neutral is usually one of the two main input shaft bearings. Those are easy to replace without rebuilding the entire unit. They seem to be the first (or only?) thing to wear out in those transmissions, unless abused by running without fluid or harsh driving.
Old Apr 9, 2010 | 05:37 AM
Juans_MX3's Avatar
If I press down the clutch it goes away. No noise in nuetral.
When i get into gear it kind of makes the noise sometimes.
Doesnt happen when the car is cold.
Ok, ill check the fluid level
darkside
13
Sep 26, 2011 07:38 PM
NellyBly15
May 27, 2009 07:02 AM
honda_civic84
Jul 6, 2008 05:36 AM
Tomo!
Apr 28, 2006 02:02 PM
mill$civic
Jan 19, 2006 01:08 PM
