2 noise related questions
I am new to the forum, so please bear with me.
I have a 2000 Civic AT. Starting the engine cold and reversing I am hearing a hissing/buzzing/squeak sound coming from behind the dash. It is difficult to pinpoint if it is coming from the engine compartment (which I am sure it is) because the sound goes away when I engage in park and get out.
Also, when driving at higher speed, 50+, I get a sound like a few metal washers on a metal rod. The sound is loud in the passenger compartment, but is coming from the engine compartment, because I can hear the sound bounce off the concrete. Again, it is difficult to pinpoint because it only happens at higher speeds.
Any thoughts of where to start?
The easiest thing to do is to have someone in the car and put the car in reverse while you listen with the hood open. make sure that person's foot is on the brake pedal. this way you don't have to be sitting in the car trying to isolate a sound from the engine compartment.
the 2nd sounds seems to indicate that something is loose. I'd look at all the motor mounts personally. it could also be the heat shield rattling as well though this is most noticeable at idle.
I thought it might be a shield, but would that explain why I get the sound when traveling at higher speeds, it usually stops when I bring the speed belo 50.
I had a cracked heat shield that produced a high pitched whistle/squeak sound at times.
Not common for an exhaust shield; however, sounds that rely on vibration can manifest under a variety of conditions, so it's worth looking into.
I'll take a look at it later tonight.
LetsGetCivical
Jan 17, 2008 12:37 PM
Esquirrel
55
Feb 6, 2006 04:18 PM
