Brake Pads
Old Nov 11, 2008 | 09:06 AM
deyjason's Avatar
Default Brake Pads
I am attempting to change my brake pads. 2005 Civic LX Sedan. I jacked the front end up. Put jack stands under the vehicle. Took the tires off and and removed the 14mm bolt on the calipers near the bottom. There was another bolt near the bottom with a boot but I didn't think I needed to remove that one. Anyhow, I can not get the caliper to rotate up to off the rotar to remove the shims and pads. I did not want to use too much force and break something. Am I doing this correctly? Should I just beat the capilper up, should I loosen the top bolt first? Any suggestions are welcomed. I just don't want to break something that costs me more in the long wrong. Thanks.
Old Nov 11, 2008 | 09:09 AM
This should help:
Old Nov 11, 2008 | 09:12 AM
deyjason's Avatar
I was looking at that diagram, I think I remove the bolt described in step 1 but the caliper will not pivot up.
Old Nov 11, 2008 | 09:19 AM
Post a picture. You may have removed a bracket bolt rather than the caliper bolt.
Old Nov 11, 2008 | 10:00 AM
You may need to push the piston back a little so you have clearance to swing the caliper out. Either put a big C clamp between the outer pad and the back of the cylinder, or pry between the outer pad and the two fork part of the caliper. You can push the piston back all the way (skipping briefly to step 10) this way in preparation to install the new pads. It is important to check that the reservoir on the master cylinder doesn't overflow.
Old Nov 11, 2008 | 11:07 AM
deyjason's Avatar
I'm stupid, RonJ was right. It was the wrong bolt. I got it done now though. Thanks
j2performance
Jan 15, 2008 01:48 PM
asdfasdfdasfasdf
Feb 13, 2006 07:03 PM
AgentofDarkness
Jan 24, 2006 12:34 AM
dc5pro
Jul 1, 2004 10:57 AM
dc5pro
