2 questions, windows & scv
Hi i have an ej8 civic coupe (pics when i get time!) i need a new mechanism for my drivers window as it has sheered inside and wont go all the way up! There is a 3 door eg at my local salvage yard, wondering if that would fit?
Also a friend has a single cam v-tech engine, D16y8? is it possible to put the head of that on my non v-tech ej coupe, i think its the same block?
any help with this would be greatly appreciated
thanks shay
thanks shay
yes your friends d16y8 head will fit on your block and just get a vtec ecu and wire it up yourself.. you will also need a vtec wire harness to cut. you need the vtec plugs from it.
and i also believe you will need to add a knock sensor. i doubt the eg window stuff will fit your ej.
TiaMarie
Sep 14, 2011 09:25 PM
wigo
Nov 6, 2010 11:18 PM
Bostonhoodhop
May 18, 2007 02:13 PM
