2 very simple tech questions
Old May 20, 2009 | 02:54 PM
Chimerical's Avatar
Default 2 very simple tech questions
My Civic DX just had its idle air control valve cleaned out well - it was gunked up, and would shut off when I try to idle. I would feel a slight shutter, and then things shut off.
I got my car back from the shop last night, and today I drove it nearly 100 miles with no issues (that was one hell of a test drive). But, I have two questions.
First off - when I idle, I still feel that slight shutter at times, but the car doesn't shut off. You can tell the motor either quiets/strains/etc after the shutter, but things pick up and the car functions as normal. Is this normal for a Civic when idling? I am wondering if the shutter was actually the IACV opening, but since it was clogged no air could get through, and therefore it would shut off. Am I on the right track here, or does something need to be adjusted?
Also, when I drive and hit around 30-40 mph, the car shakes a bit. Not much, and the car runs fine, but I typically give it more gas or slow down a bit to take it out of that gear (automatic, but I can feel it shift). Is there a reason why it may be doing this?
Thank you all for your help!
rydnlow1120
12
Feb 5, 2008 05:53 AM
2000 Si Newbi
Apr 18, 2007 04:58 PM
TheMoogly
Aug 29, 2006 04:29 PM
mill$civic
Aug 16, 2006 01:36 AM
mill$civic
Dec 15, 2005 06:27 PM
